Hi chaps and chappesses.....
Could someone point me in the direction of where I might find out what the timing wheel pattern is in my 1994 B18F please..? Interweb didn't turn up anything useful but I might have been looking in the wrong place.
Is it something 'normal' like a 60-2 or a 36-1 or something a little more exotic (seem to recall some 44-2-2 or similar). As far as I can tell, there's no cam tooth/teeth to worry about.
I'm not being lazy, it's just that I don't really want to drop the gearbox out, just to count teeth...!
Thanks in advance,
Rick
PS/Edit.... Found a thread in here re. the 'Turbo' timing wheel.... Is the non-Turbo version the same..? If the type of wheel changed in 1994, I might be on the cusp..! .WAV file is a good call and DTA do something similar with their ECUs....
Timing wheel pattern B18F
- jamesy12345
Re: Timing wheel pattern B18F
Do a search on teeth within this thread...
http://www.volvo-480-europe.org/forum/v ... 7&start=20
Any use??
edit
further to the above, here's a bit more info and a way to count the teeth without opening it up
http://www.volvo-480-europe.org/forum/v ... 11&t=14907
Any use??
edit
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
