hard to start b18ft
hard to start b18ft
hi ' engine been out a few years 'had a few teething troubles with wiring etc and is very is starting too good from cold but once running for a few minutes starts ok altho after about 3 seconds 'i have new distributor cap 'plugs 'leads rotor and new camshaft oil seal which was leaking into dizzy cap 'i have double checked wiring and everything looks ok 'any ideas would be much appreciated 'kev
Re: hard to start b18ft
also the wiring for the oil temp sensor had come adrift and rewired it but doesnt register on info centre and neither does the water temp on info too' fuel pump doesnt prime with ignition and has always been like this 'oh dear i think i have my work cut out
Fuel pump on b18ft doesnt prime, it only works when cranking.
Does the car have fresh fuel?
- jamesy12345
- 480 Veteran
My 460 has the same engine, starts easily cold but doesn't like to start hot and runs rich I think...worth checking lambda sensor?
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Do you still have the cold start sensor plugged in on the head under the throttle?
hi ' yes fresh fuel and cleaner but the cleaner was put in later ' yes connectors all seem fine altho i had a few that had come way but resoldered etc 'when it had started and blip the throttle it also cuts out 'once running for id say 30 secs seems to start but not great ? ' thought the early turbos fuel pump primed on ignition ? no cat so no lambda sensor '89 turbo 'and thanks for all replies
Have you got the fule pipes the right way round?
I know i had this mistake, but it wouldnt run for 3 seconds let alone 30
- jamesy12345
- 480 Veteran
aha B18FTM...sorry thought it was with a cat. My 91 has one.
My 93 car has bodged wiring to the sensor Sparky mentions above. Maybe worth checking this is getting back to ECU?? There is a thread on here somewhere I'll take a look
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
once its running it runs all day long 'altho a little lumpy 'if i keep it say at 4k revs you can hear it missing ????????
- jamesy12345
- 480 Veteran
The thread I was talking about...
http://www.freewebs.com/hjkort/480ecus.htm....pin 2 of the ECU is for the coolant sensor...may be easier to check it that way
http://www.volvo-480-europe.org/forum/v ... =3&t=16611....and resistance values.
But maybe not coolant sensor? Rough running.....spark plug gaps, make them smaller for the Richmod! Just guessing if the coolant temperature is not showing on the info panel then I guess that is a good one to start with.
Looking through old posts on the forum it could be a few other things:
ICV
Distributor cap, leads, plugs (you said you changed them but make sure u don't have any duff ones)
Loose wire/bad connection including earths....easy to write not easy to find
MAF
Air leak (does the turbo gauge take a long time to get to minus 14 psi when it starts up? If so get the Easystart out. Maybe thin black pipes on the inlet manifold...)
Clogged injectors or fuel filter
Good luck fella just work through the list and any more u can think of! Will get there in the end
ICV
MAF
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Give it a compression test aswell
- jamesy12345
- 480 Veteran
Good thought...POE you have some list now! Hope it is something simple
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
yes i need to make a check list 'hope it doesnt get too long 'its a good job im in no hurry too 'thanks guys and will keep you posted
well last night i checked the resistance of temp sensor and it was 0 'had car running for approx 10 mins with few revs on and checked again and still 0 'dead ? checking the rest at weekend when i have a free day
- jamesy12345
- 480 Veteran
was that at the ECU plug or at the sensor?
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
sorry it was at the sensor
- jamesy12345
- 480 Veteran
sounds like the sensor has gone then. Hopefully a new one will sort it!
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
managed to get a temp sensor from work off a vauxhall to try 'wired it up to volvo and started first time 'will order a new one from ebay 'thanks for all the input 'much appreciated and sure it wont be the end of my problems 'cheers
- jamesy12345
- 480 Veteran
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
another question i have is what is the odd shaped sensor that bolts to the inlet manifold on the right hand side? aluminium sensor with two wires coming from it 'another temp sensor? i have done an ohms test and also reads 0 whether hot or cold 'thanks
