Sensor question
r5b18ft
Sensor question
Post by r5b18ft » Wed May 09, 2012 8:41 am
What is the sensor on the intake/MAF hose at the end of the engine breather pipe ?
And will it effect the running of the engine if it is unplugged ?
Thanks :D
r5b18ft
Re: Sensor question
Post by r5b18ft » Wed May 09, 2012 8:42 am
Forgot to mention, its a 480 turbo
Melvin480
Re: Sensor question
Post by Melvin480 » Wed May 09, 2012 9:36 am
It is a heater element. To prevent formation of ice in the winter from condensed water vapour from the breather. You can imagine what would happen if a piece of ice falls into the turbo.
r5b18ft
Re: Sensor question
Post by r5b18ft » Wed May 09, 2012 9:47 am
Melvin480 wrote:It is a heater element. To prevent formation of ice in the winter from condensed water vapour from the breather. You can imagine what would happen if a piece of ice falls into the turbo.
Thanks for your reply ! :D
Then it is useless for me, as I live in Malta. Odds are water vapour would turn into steam rather then condense :lol: It's already 27 degrees celcius here
