I'm sorry not to have introduced myself, but I couldn't find the topic for that.
Short introduction; I'm Willem-Jan from the Netherlands and I have owned 4 Volvo 480's. My first car was a red Turbo, after that a white Turbo as a donor for my R5 GTT project, a blue/grey ES Automatic and a grey metallic Turbo.
Recently I got the chance to get my first car back, the red Turbo. It has been sitting in a parking lot for 3 years, so it had some work.
I have welded in a big piece of the sill, replaced all brake lines, brakepads and discs and some other small parts. Now it's almost ready for the APK (Dutch MOT), but I can't get it running.
The fuel pump doesn't get power. This is what I found out so far:
- The fuel pump itself is working (tested it with directly 12 Vdc)
- The Main relay clicks when the ignition key is turned
- The Fuel pump relay doesn't click
- The fuel pump relay itself works (I have put the 85 of the relay directly to the ground with a piece of wire) and the the fuel pump works.
- Pin 17 of the computer does not make the connection to the ground as it is supposed to do when I turn the ignition key.
- I have switched computers, but this doesn't help (same numbers on the computers)
- Fuse 12 in the fusebox in the car is OK and so are the 2 fuses at the Main- and fuel pump relay
So now, I don't know where to look now. Does anyone have an idea?
Fuel relay does not work
Re: Fuel relay does not work
need to know year of manufacture .
Year of manufacture is 1991.
And I would like to add to the story above that the engine was working when it parked 3 years ago.
Hi Willem Jan, maybe take a look on the dutch volvo 480 Forum.
I think I can help you because I only do repairs and maintenance on 480's.. no other cars.
My nickname there is the same as here.
Just pm me.
Regards,
Jeroen
Just pm me.
Regards,
Jeroen
