B18EP/FP engine with B18E electical installation
bigdickbuster
Post by bigdickbuster » Thu Jan 05, 2012 8:56 pm
Hello guys and gals :)
My friend have problem two problems: He lose his password to this Forum. This is first problem. Second, more important is:
Did the B18EP/FP engine will work with electrical installation/sensors etc. from B18E engine? He make a lot of work, unfortunately useless. Car have 4-6 KRPM in the idle.
Your advices are last chance!
Thanks in advance!
Adrian
Re: B18EP/FP engine with B18E electical installation
Post by glasgowjim » Fri Jan 06, 2012 1:26 am
Hi Adrian
what about the engine management unit ? Does this match the engine. What colour is the engine temperature sensor (next to plug 1) is it blue or black plastic as there are 2 types.
regards jim.
Post by glasgowjim » Fri Jan 06, 2012 1:27 am
Oh Adrian contact volvobigbrother who can sort things for him.
bigdickbuster
Post by bigdickbuster » Fri Jan 06, 2012 10:39 am
Hello Jim!
Thanks for the response. He replaced ECU two times and all sensors. He replaced inlet manifold because he suspected air leak. Everything was useless. He bought this car and engine had problem with idle. He found a lot of strange solutions under the bonnet. He wanted to organise this mess. Now, mess is bigger than was before he started ;)
Post by glasgowjim » Fri Jan 06, 2012 11:04 pm
just a quick thought check the flywheel sensor some had 3 wires and some 2 .
Post by glasgowjim » Sat Jan 07, 2012 8:59 pm
with reference to my last post here....
: car wont run tick over or rev up
by glasgowjim » Sat Jul 31, 2010 10:31 am
as I quoted in 480 clio's other thread
Re: ECU AND FLY WHEEL OPTIONS SERIOUS HELP NEEDED PLEASE !
by outlawmorga » Sat Jan 23, 2010 7:26 pm
simple as this... the older engines usually running with a black coloured intake manifold will run a different crank sensor which means different wiring loom which means different ecu's. For example i have a 1993 engine with silver inlet with 215mm plate running blue ecu's with a 'two' pin crank sensor... this only allows me to run the later ecu's. Some of the older engines have 3 pins on the crank sensor and will only run 200mm plate with older orange ecu's i don't know where all these other colours go, as in which flywheel size they run all i know is you can only run a later flywheel with a later ecu
Renault Clio Running B18FT with rich mod, fse boost pressure valve, n/a camshaft taken from clio RSi and bleed tap
outlawmorga
bigdickbuster
Post by bigdickbuster » Tue Jan 10, 2012 9:21 pm
Hello again Jim. Many thanks for your attention. I will send your answers to my friend, he would be glad!
Adrian
swital
Post by swital » Wed Jan 18, 2012 3:58 pm
bigdickbuster wrote:My friend have problem two problems: He lose his password to this Forum.
Hello
It's me :) I fixed my problem with password.
The car is at the mechanics and he is close to repair him. He said i must change the engine wires and ECU those from B18EP, becouse with wires and ECU from B18E this engine will not work properly. Yesterday he call to me and said that he put the nozzle to hose of crankshaft ventilation (he said that the nozzle should to be there, but somebody took her) and cold engine on idle have a 1100rpm. I searched in Vadis something about that nozzle, but I haven't found anything.
That the nozzle should be there? I have already ordered engine wires and ECU from EP and I will install it on the weekend. Ofcourse I will change all engine fittings this from EP, becouse currently is this from E.
480S B20F 94' Paris Blue Metallic
480 Collection 158/480 B20F 95' Drak Green Metallic
480 Turbo 92' 234 White
744 USA Turbo, 245 USA D24TIC++, 854 T-5R, 245 Hearse, V70II D5 Polestar, C70 I Cabrio, 440 88' B20F, V70I 2.5T Heico
Post by glasgowjim » Wed Jan 18, 2012 6:05 pm
swital
Post by swital » Wed Jan 18, 2012 10:00 pm
Jim, thanks. so I must check idle on wire and ecu from EP and without nozzle. We will see in a weekend ;)
swital
Post by swital » Mon Jan 23, 2012 11:56 pm
I received a car on saturday from mechanics, and EP engine works on fittings, wires and ECU from E :hopping: Only ignition is moved by 4 degrees, so the combustion can be a bit bigger.
In crankshaft ventilation sholud be a nozzle in the black plastic tee. I have a pic of that nozzle, but i can't add links yet.
Post by glasgowjim » Tue Jan 24, 2012 6:30 pm
email to me and I will post them up for you ( you need ten posts before you can put up a picture.)
Post by glasgowjim » Tue Jan 24, 2012 10:36 pm
nsmdm
Post by nsmdm » Sat Jun 30, 2012 11:25 pm
Great 1 post
