cold start problems
Posted: Sun Nov 06, 2011 5:54 pm
by Zoist
Hi
when the engine is could and i start it up, it sounds like one of the cylinders dos not fire up and I can hear a popping sound some times. and it has to ges some revs for a few minuets before i can drive it... if I try too soon it dies...
the spark plugs is new, can anyone give some help?
Re: cold start problems
Posted: Tue Nov 08, 2011 10:22 pm
by glasgowjim
check distributor cap and rotor.
then check the spark plug leads.
does it run ok when warm ? if so check engine temp sensor.
Posted: Wed Nov 09, 2011 7:23 am
by Zoist
when warm it runs perfect.
this weekend I am going to change the distributor cap, rotor and spark plug leads. witch sensor is it that you are referring to? the one pin or the 3 pin sensor?
Posted: Wed Nov 09, 2011 11:01 am
by Captain Slow
If it ran ok before the new spark plugs....was a mistake made with their fitting?
Posted: Wed Nov 09, 2011 3:19 pm
by Zoist
it had the same problem before i changed the spark plugs
Posted: Thu Nov 24, 2011 2:02 pm
by Rachel
Check this out
http://www.volvo-480-europe.org/forum/v ... 11&t=12966 I had bad cold start issues a while back and it turned out to be the Oil Separator Valve mentioned in reply 7 or 8 I think (thanks to martinholmesuk
) Worked for my 480T. I hope that helps
Posted: Sun Nov 27, 2011 1:35 pm
by Zoist
Hi
Well I have found that the rev are too low when I try to could start. It can be helped by adding a little rev the first minute. then it is fine in idle. but the car wont accelerate when could. it has to be in idle for a long about 2-4 minutes, sometimes longer, before the engine will run past 2000 RPM. If I try to hit the gas, it just stops at 2000 rpm and just stop taking rev´s. But when the engine gets warm, there is no problem.
Dos any one has a picture of the mentioned sensors? diaphram and recirc valve? I have to be sure what you guys mean and talk about.
so pictures of the things and where they are placed would be great
Posted: Mon Nov 28, 2011 2:04 pm
by Rachel
Hi...here is a picture of the oil separator valve. When mine needed replacing it just caused low lumpy idle when starting from cold until it warmed up. No other issue after that and revs when cold didn't help, so maybe it's not this, but could be part of the problem. If I remember rightly it was about £45 from volvo so not a cheap part.
![Image](http://i81.photobucket.com/albums/j235/miley_2006/ebaypictures044.jpg)
Posted: Mon Nov 28, 2011 2:12 pm
by Zoist
Hi
It is a different idle valve you have. my car is from 87.
My car dos not have such a valve...
Posted: Mon Nov 28, 2011 2:45 pm
by Rachel
Zoist wrote:Hi
I was showing the oil seperator valve not idle control valve. The black thing attached to idle control valve. Maybe that's different too then
Sorry
Posted: Mon Nov 28, 2011 2:48 pm
by Zoist
Hi
My idle valve is shaped different. and I do not have the black valve as your picture shows.
Posted: Mon Nov 28, 2011 3:04 pm
by Rachel
Well bang goes that theory then!
