I'm desperate to get this baby through the MOT but bless it there are a few issues going on
According to the MOT sheet from last year, it scraped through last year with an advisory about high CO at idle. The previous owner reckoned it might need a new cat.
I tested it this weekend on my basic gunson and warmed up I'm getting an idle reading of 0.7% CO (plus or minus 0.2 - not the most accurate device). I think this exceeds the allowable level so I'm expecting an MOT fail. Slightly more troubling is the fast idle (1400rpm) which gives a reading of 1.1% - surely CO should go down not up at higher revs?
I tested the lambda probe today and that seems to be working okayish - returning voltages oscillating between 0.2 and 0.8V at roughly 2Hz. I think that's slightly sluggish but it might be that my digital voltmeter cannot keep up.
My gut instinct from the way she drives is that she's running rich. So what's the verdict - is it worth getting hold of a replacement cat and lambda for the MOT man or is it likely to be something else. Incidentally as well - does the engine temp sensor (the one which determines mixture) also inform the infocentre or is it a separate job? Infocentre temps read fine, ironically enough!
Thanks,
Dave
