Hello everyone,
If I start my Volvo L reg Turbo and drive it, the clutch is fine, even under heavy acceleration.
How ever, if I leave it idling a little to warm the engine up on a cold morning or end up sitting at traffic lights for a while the clutch will then slip like crazy.
Any suggestions?
I have been informed the clutch itself may be fine as if it was warn or damaged etc. it would slip all the time. Some one said it could be a "crank shaft oil seal" leaking onto the clutch?
Any help is apprechitated.
also if it is the clutch where can I get one from as EVERYWHERE I have looked has been out of stock. I ordered one ages ago from TMS and it was on order for a month claimining "It was coming" so I just got my money back in the end.
thanks.
Clutch Issue?
Clutch Issue?
.:Volvo 480 Turbo:.
Re: Clutch Issue?
Could very well be the oilseal. But either way you have to replace the clutch. A new oilseal and new clutch is a gearbox out job, a new oilseal will cost you less then a tenner. If you can't scource a clutch new you can have your old clutch reconditioned as option.
Partsforvolvosonline sells clutch kits for the turbo, dunno if they have them in stock though!
Re: Clutch Issue?
Thank you for the help
My dad owns a garage so not scared of any work as I have a spare car which I have put on the road while I take the volvo off the road to make it a stunner
.:Volvo 480 Turbo:.
Re: Clutch Issue?
i would get the clutch resurfaced with racing compound for £30 ish in manchester by return post if i was you . also you can buy a 150bhp clutch , if yours is 215mm by buying a RENAULT 19 phase 2 16v clutch , which can be found on ebay for under £50 for the whole clutch kit !!! cheers Felyx
heres one for £42 including next day delivery , they have ten
http://cgi.ebay.co.uk/CLUTCH-KIT-RENAUL ... 3363605c52
these are £82 delivered ha has 5 http://cgi.ebay.co.uk/Panther-Clutch-Ki ... 483d9ea1f4
Re: Clutch Issue?
A proper volvo gearbox oil seal will set you back about £26 including VAT at 17.5%
Re: Clutch Issue?
That's not too bad
My Volvo is going off the road and into my dads garage to get as much as I can repaired, replaced or upgraded Really love my 480 I just want to get it as tip top as I can.
Ant.
Ant.
.:Volvo 480 Turbo:.
