Fuel pressure regulator
- chriskay
For some time I've been aware of a hesitation when calling for maximum acceleration. My friendly local Volvo service manager told me it was probably the fuel pressure regulator & that he'd known quite a few give trouble (my car has only done 77,000 miles). Stores looked up the part No. & wanted about £90+ inc. VAT. He confirmed that the part seemed to be common across the range, so I hoped I might find one at a breakers. I was able to read the Bosch part No. on the regulator so went to my local motor factors. They got me one next day for £56. I fitted it today & it's completely cured the problem. Also, power delivery through the range seems smoother & it's also cured a slight jerkiness at idle speed. Altogether, I'm pleased. Fitting is straightforward; it's worth getting a bit of 8mm. fuel hose & a couple of hose clips; you only need 40mm. of hose but it allows you to cut off the old, which makes the job easier. Bosch part No. is 0 280 160 280.
2 Kings; Chapter 9 Verse 20
when looking on ebay type in "variable fuel pressure regulator"
which will show you loads of nice german made oil filled ones witha clear reading built pressure gauge for about £45 !!!!!!
http://cgi.ebay.co.uk/Variable-Fuel-Pre ... 286.c0.m14
UPTO A MAX OF 7 BAR !!!!!
just squash it in a vice endways to up the fuel pressure.
http://cgi.ebay.co.uk/Fuel-Rail-Adaptor ... 286.c0.m14
youl notice it has the same bolt holes and seal as your old regulator.bolt this in its place and connect the pipe to the ninlet on the adjustable regulator.the other two are pipe connections and go to the outlet and vacuum.
why would you use it to replace the original?
- chriskay
Re: .
My point exactly. I would only use it to replace the original if I wanted an adjustable one, which I don't, or if it was cheaper, which it isn't.ted clutch wrote:why would you use it to replace the original?
ive just read your first post. i thought you wanted an adjustable one. interesting to know.mine has a bit of a step in acceleration at low revs its troubled me for some time.may be worth a try.where did you buy it.
- chriskay
I bought it through http://www.cesuk.com/ they operate in the North West. I don't know where you are, but I'm sure your local motor factors will be able to get Bosch parts; part No. in my first post.
