lumpy idle
clio 480 turbo
lumpy idle
Post by clio 480 turbo » Wed May 06, 2009 12:14 am
my car on tick over is lumpy revs constanly drop to near cutting out then build up to about 1500rpm then repeats the fault i have changed the icv but could both be dodgy.
B18FT - LOVER
Re: lumpy idle
Post by B18FT - LOVER » Wed May 06, 2009 6:28 am
clio 480 turbo wrote:my car on tick over is lumpy revs constanly drop to near cutting out then build up to about 1500rpm then repeats the fault i have changed the icv but could both be dodgy.
Quite possibly mate they are prone to dying and getting gummed up with muck from the inlet..
Also check all your vac hoses, make sure you have no air leaks.. :D
M D E
Post by M D E » Wed May 06, 2009 8:34 am
I had the same problem solved mine by cleaning the air flow meter ... Easy to remove just two clips plus the sensor cable, gave it a good spray of WD40 cleaned internals with a rag ... Mine has a stable idle now ..
480 TURBO
C70 T5 LPG Convertible
bkf_uk
Post by bkf_uk » Wed May 06, 2009 5:20 pm
a bad lambda will also cause a bad idle
Toys:-
94 440 turbo auto (Sent to the main dealer in the sky :cryhard: )
