wheres the air temp sensor
POE
Post by POE » Mon May 04, 2009 8:04 pm
is it true that air temp sensor can sometimes cure high idle problems ,have renewed idle valve with no success ,the other is where is it ,is it on the pipes leading to the turbo and is it tubular with a brass element running through it? 89 turbo.
yknot
Post by yknot » Mon May 04, 2009 8:40 pm
b18ft has no air temp sensor, it has MAF
volvo 480turbo 1990 RICHMODED, adjustable FPR, SSQV BOV, free flow exhaust. - sold
1.6 16v Suzuki Samurai with many mods.
Nissan Note DCi
POE
Post by POE » Mon May 04, 2009 8:43 pm
bugged that idea up then :lol:
ted clutch
slash/
Post by ted clutch » Mon May 04, 2009 8:47 pm
:eek: hello buddy.i dont know abowt turbos but i had a high idle after a quick thrash. everything drastic and dramatic went through my mind thinking id damaged 't' engin. the throttle stop screw had vibrated in at full thrash it was that loose. so simple and cheap i didnt spot it until much head and chin scratching had taken place. :cryhard: :angry: might be worth a look. ;) :D :rofl:
POE
Post by POE » Mon May 04, 2009 8:52 pm
hi,it only increases when at operating temp then stays there, ive even changed the maf for another one with no result,everything has been cleaned out ,all pipes removed checked and made sure nothing is leaking but still nothing :(
bkf_uk
Post by bkf_uk » Tue May 05, 2009 12:59 am
might be a bad lambda or a dodgey engine temp sensor. otherwise it might just well be the dreaded icv thats playing up.
Toys:-
94 440 turbo auto (Sent to the main dealer in the sky :cryhard: )
POE
Post by POE » Wed May 06, 2009 6:31 pm
hi ,whats the ICV ?????? :? engine temp sensor sounds like next job, have no lambda sensor
POE
Post by POE » Wed May 06, 2009 6:34 pm
oh the idle control valve ,silly me :D i have recently replaced with another but the same ,i know there the fact that this might be buggered as well?
