What's this hose connector good for?
Hello,
I'm the owner of a 1.7L Volvo 480 ES.
Any ideas what the hose connector (big one, like for air) on the opposite side of the engine oil filler cap is good for or what it should be connected with, as there is a buckle but no hose.... it seems to be part of the injectors bar. I found no other unused connector to which it might be connected to. First thought it might be part of the oil vapor recycle system.
Tried uploading a pic of it, but as i'm not registered long enough, no chance. Hope you get what i mean.
Got my Hanyes manual ordered, but not recieved it yet.
Greetz
Raff
Greetz
Raff
Thx Martin, well one more problem which might be related with that thing.....horrible vibration noises coming for the area between inlet mainfold and the injectors... might there be something loose on the cooling thingie which might give metallic rattling noises?? They are really bad/loud between 2500 and 3000 rpm...which is bad, because that's the rpm when driving within city...
Greetz
Raff
Greetz
Raff
- B18FT - LOVER
Did you have to replace the mainfold inlet gasket? As this plastic cooling part can be source of horrible noises, which i temporarly got rid of, be readjusting the clips holding it together. But i want to remove it as soon as possible. Do you have to disconnect all the hoses leading to the inlet or only main bolts?B18FT - LOVER wrote:I just removed mine, works fine..
Greetz
Raff
