Hi all
Not sure if this is in the correct place to post this, but I am looking to adjust the throttle cable. I want the pedal in the car to be lowered - it currently sits at the same height at the brake pedal and I feel that at cruising speeds, my leg is strained.
If I understand the basic operation of the cable, I must take up some extra slack (i.e. shorten) the cable to achieve this. If this is the case, what's the easiest way to go about this?
Many thanks,
James
Throttle Cable
- surrealjam
