I Removed Engine to allow clutch chage / timing / etc etc. Engine back in, ran for about 30seconds rich then died. Now refuses to start.
Checked Spark (on all 4)
Checked fuel pump running (even bridged fuel pump straight to battery)
Crank Sensor seems ok, resistance in values as stated by Haynes.
Whats the best way to eliminate problems? As I understood all the car needs to start is Crank Sensor? Not that I've unplugged anything else yet, as surely even with dodgy sensor somewhere it should start!
B18FT won't start.
B18FT won't start.
1998 Nissan 200SX - RWD / 260 BHP :)
1990 Volvo 480 Turbo - Sold
1994 Volvo 480 Turbo - Sold
1990 Volvo 480 ES - Broken
- martinholmesuk
- 480 Veteran
I'll check these tomorrow hopefully, bit antisocial to be cranking her over now! (plus its raining!)
I'm ok with mechanical stuff, but diagnostics is not my cup of tea!
Appreciate help so far.
Power to LH - Yes480_rocket wrote:You got spark, so I would take a guess EZK and that lot is working.
Things to check:
Power to LH ECU OK?
Check power on injector harness.
Does rev counter move up when cranking?
Injector Power - Yes
Rev Counter bounces on startup.
