Newbie with '87 480 ES
- bigdickbuster
I'm sorry about my english, i will succesive try to write better
Hello, Half year ago I've purchased from my friend his Volvo 480 ES. Then I
i don't knew that Milosz_480 was previous owner. Now i know
The car is amazing and i love it
I have a problem with my Volvo. In the tank was few liters of water. Probably this was a reason of Milosz problems with low power of engine.
I remove the water from the tank and fuel pipes. I fix the injectors, because they are stopped after the car stay about one year. I change the spark plugs.
Car have now good acceleration, but between 2000-4000 RPM worked only 3 cylinders. After the 4000 RPM works four. It looks like electrical problems, something don't contact.
What must i check to fix it?
Regards
Regards
ex 1990 480 TURBO, model year '90, 231 Red This car was a mistake
- bigdickbuster
Thanks for the reply. All basic elements of the ignition were checked. They aren't demonstrating faults. It is possible to feel breaks at the ignition as if in the process of the work of an engine one cylinder was detached or connected. This way from 2000 RPM is happening to 4000 RPM. Above this value the car is speeding up as the jet aircraft. Can it be caused by the CEM breakdown?
P.S. Online translators are not so good. They are doing many mistakes, like me
- bigdickbuster
CEM does not control the ignition there is a separate controller for the ignition. I have spares for both 1.7 and 2 litre engines if required.
The cem is in a black plastic box on the left side of the car when you are sitting in it. The ignition controller is in a steel box on the rightside of the car. It will have a seial number on it and you can cross check this against the elctrics spares list I have posted should you need an ignition controller and can not find one.
Z poważaniem
Jim.
no mistake with this polish expression
Z poważaniem
Jim.
- bigdickbuster
- bigdickbuster
- Ettore Bugatti
- bigdickbuster
- Ettore Bugatti
Thank you!bigdickbuster wrote:Welcome!
In downloads department there is exactly a scheme to B18FT. B18e isn't.
Im pretty sure the B18E is in there too (B18E/D B18E/S is similiar)
The B18E has a renix type ECU which controls the fuelling and ignition. The B18FT use bosch stuff LH2.2 and EZK216 (so seperate units for fuel and ignition).
The B18EP/FP also use the renix ECU as the B18E, but the wiring has changed. Since sensors and pin settings of the ECU has been changed.
Rover Mini 1000, june 2009-
- bigdickbuster
Perhaps I didn't look exactly. I will check one more time. Is there a way to check mistakes of the computer? B18E probably doesn't have the test connector in the ECU?
After today's tests I think that an injector of fuel is creating problems. Is it possible to check it by ECU?
- Ettore Bugatti
The early ECU's (Fenix 1 and 3.2) are very limited in test functions.
- Are all the spark plugs OK?
- You can perhaps clean the fuel injectors or install new ones (The B18E use the same injectors as a BMW e30 325i, if I remember correctly. It is one of these Bosch part numbers: 0280150126, 0280150740 or 0280150741)
- Perhaps it helps to disconnect the battery for half an hour to reset the ECU?
- Check and clean your earting points (of the electrical circuit)
- bigdickbuster
Spark plugs are new. I erased ECU by excluding the battery. Unfortunately it didn't help. Will some injection slat from V440 with the 1.7 engine fit to my engine? I can buy used. Visually he looks on the same?
- bigdickbuster
- bigdickbuster
I found it!
I will paste the link in a minute.
General Error
In order to try to prevent spammers, we do not allow our users to post URLs in any form until they have posted at least 10 legitimate posts and have been with us for more than 7 days. We appreciate your understanding in this matter in order to help us eliminate spam from this forum. If you have somehow gotten this message even though you meet both of the criteria, please let us know ASAP.
Thanks!
- bigdickbuster
- bigdickbuster
it came off
http://moto.allegro.pl/item471839019_vo ... ryski.html
And here is a few photographs of the patient:
http://img390.imageshack.us/my.php?imag ... 010fg8.jpg
http://img509.imageshack.us/my.php?imag ... 011bo4.jpg
http://img120.imageshack.us/my.php?imag ... 012tq0.jpg
http://img520.imageshack.us/my.php?imag ... 022kh3.jpg
EDIT:
You mean BMW 2,5 litres (m20b25) e30 engine?
EDIT:
- bigdickbuster
My car has two broken injectors. I found injectors to my engine. Unfortunately it has a defect. You can see it on the photography. It is a crack. Whether is it an important thing? Whether I must search new injector?
http://img133.imageshack.us/my.php?imag ... 149gy0.jpg
Re: Newbie with '87 480 ES
Hi All. Is there any place to download ecu to engine sensors wiring diagrm for B18E engine? I have many wiring diagrams and schemes but no one with B18E. Need help with it.
May be someone know wiring for B18E sensors to Fenix 3A (Fenix 1 / Fenix 3.2) ECU ?
Thank you in advance!
P.S. Volvo 480 1987
ECU - Fenix 3A (Fenix 1 / Fenix 3.2)
Engine - B18E-104
P.S. Volvo 480 1987
Engine - B18E-104
Thank you for your time!
With best regards,
Dennis
With best regards,
Dennis
- jamesy12345
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
