Few questions from a newbie :)
Clio_RSibrid
Post by Clio_RSibrid » Mon Oct 27, 2008 11:31 am
Hi, ive got a few questions regarding my 480 turbo engine. As you can probably guess from my name i am going to be putting the engine in my clio and i want to make sure everything is complete before i put the engine in.
The fuel pressure regulator only has one pipe going to it, the connection pointing towards the inlet manifold has no pipe coming from it and i need to know where this pipe connects to.
Also where do the vaccum pipe go to from the top of the actuator? There is a connection there but again no pipe, its a small connection so i am guessing its some sort of vaccuum connection.
Thanks in advance.
