pol wrote:Fair bit going on in there! Wow,!
I spotted the new outlet on the manifold where the plug normally is, and there's an FSE over there... Oh and a big supercharger... You've fitted braids over the standard intercooler / turbo hoses, good plan! Makes me spending a few hundred on new suspension soon seem like pennies..
There is a lot there alright. That's what has taken so long, most of it was fiddly and chalanging to make, or expensive to buy.
The FSE is going soon. The rising rate part doesn't help at all, a flat response regulator will be much better. It was just hanging about so got fitted as the pressure is adjustable.
pol wrote:
That was another thought I had about the oil breather, is it not bad for these gasses to be drawn through the turbo inlet after the MAF, as in, it won't be metered?
Not sure about that... The blowby from the piston rings has already been metered through the MAF, so it's just going round the engine again. Any upset from the small flow should be easily compensated for by closed loop oxygen control anyway.
At idle the air is drawn in through the MAF, and into the vent valve, then on to the manifold. The actual proportion of blowby gasses is resonably small compared to the amount of fresh air. If the turbo inlet pipe was before the MAF it would draw in unmetered air.
If you fit a filter then you would need to block off the two pipes to stop air geting in unmetered. Also the car will in theory not pass an MOT, as closed crankcase ventilation is required. Most MOT staitions may not check, but some could.
Richard
