bad idle
bad idle
OK tonight my 480 has started to get a fucking bad idle. Installed mbc this morning?
I don't think it's linked. What do you think?
what dump valve have ou got, was there not something about the 480 requires a twin piston one or else it will suffer from bad idel, might be now your running higher boost it can cope.
unless you have a dv26 then you should be fine, could be fuelling or youve fooked something with all your speeding about
***CAR FOR SALE 2K AND ITS YOURS***
bad idels can range from a dirty idel sensor, i heard that on the 440s the idel valves get very hot and are prone to failure, the new oil heat that your gettign whilst running high boost could be effecting the valve, if so them rap it in heat proof material, or do what my m8 did and put a cold air feed to it.
- dragon
- Volvo 480 Club Europe CREW
Did you not seal the "spare" pipeline properly whnen you fitted yer mbc?
Gaz Wilson
Gaz Wilson
