right hand door hinges volvo 480
john denmead
Post by john denmead » Thu Sep 29, 2022 3:44 pm
I am after top and bottom hinges off right hand door. I know they will probably be worn but i will get new pins made. Does anyone know if same hinges on 440/460.
Re: right hand door hinges volvo 480
Post by dcwalker » Thu Sep 29, 2022 7:12 pm
I think they're the same on 440/460 - I'll check for you tomorrow.
malkontent
Post by malkontent » Fri Sep 30, 2022 10:06 am
Hi
Have somewhere in my treasures , new and used , must find :D
malkontent
Post by malkontent » Fri Sep 30, 2022 1:54 pm
Lucky you , found one new / 3472964 / and have 2pc. used , upper and lower are the same . Used are on a car , need time to remove .
Post by dcwalker » Fri Sep 30, 2022 6:01 pm
As far as I can tell by visual comparison, 440 460 and 480 hinges are identical.
malkontent
Post by malkontent » Fri Sep 30, 2022 6:16 pm
Yes , the same part number .
Post by jamescarruthers » Sat Oct 01, 2022 5:22 am
I’m pretty sure I got new pins from the Volvo dealer a few years ago as the pin is used on many other Volvos.
malkontent
Post by malkontent » Sat Oct 01, 2022 10:05 am
Your parts , left is a new one , right is used one . I`ll send on wednesday .
regards
Marek
malkontent
Post by malkontent » Mon Oct 24, 2022 10:51 am
Hi
Did you get it ?
Post by jamescarruthers » Tue Nov 01, 2022 1:02 pm
Found these in the garage, part number 3416207 and ordered within the last few years.
malkontent
Post by malkontent » Tue Nov 01, 2022 3:09 pm
It is a pin for door stop :D
Post by jamescarruthers » Tue Nov 01, 2022 8:37 pm
Ah, yes of course! Thanks Mareck!
