most 480 turbo parts
not the best pictures as the car is still whole and driving
ring me for parts 07805391168
orange thing is a clip
this is the metal ecu rite hand side drivers kik panel green lable
these 2 are the 1s in my renault 5 as u can see there the same pair as in the auto volvo 480
- B18FT - LOVER
crank signalhas 2 wires
same as a manual
also same as r5 turbo
same as a manual
ring me if u want fella its easyer
07805391168
07805391168
- B18FT - LOVER
I don't need it personaly for myself just reevio wants it so im trying to suss it out for him..
Far as im aware he might need the crank sensor from you aswell, as the loom your selling him is a 2 pin sensor and he has a 3 pin sensor..
My advice to reevio is buy them loom, ecu's x 2, crank sensor, and the air flow meter.. You will need the air flow meter to send the correct signal to the ecu as your one may be different...
it will wrk as i have same set up in my 5
all that u listed £150 plus p&p
made payable to pay-pal
i need an answer on this as im about to drive it to the wrk shop and cut in half
- B18FT - LOVER
money received. thanks will post tomorow.
still got lots left ppl
realy goood auto gear box.
rear lights (are faded but will polish up)
boost oil an volt guage
clock set info center all works
intercooler
front and rear bumbers
both doors (pas door has a few lil rust scabs)
heater matrix
dash loom
light loom
both headlights (all working)
front nose cone thingy
wheels
suspension
neerly new cat back exhaust
4 realy nice leather seats (fronts are heated)
the shell is mint if any 1 is intrested with papers ect
front wings
every thing avaliable
intercooler
heater matrix
dash loom
light loom
wheels
suspension
front wings
- B18FT - LOVER
yup ecus are in the back bolted up to the pasanger rear quater.
didnt extend the wires, i shortened them as the original loom is very long
engine is still up the front
theres piks on here sum where
- B18FT - LOVER
it defently is that long. originaly the loom raps round the engine from pas to drivers along chasis leg up to the scuttle then in the dash
mine runs from pas rear quater to bulk head and on to engine
i will admit we lengthened the injector wires tho just remembered lol
- B18FT - LOVER
only pik i have at the mo
- B18FT - LOVER
- B18FT - LOVER
im really sure we shortened a bulk of it my loom goes strait through the bul had so dosnt loose any length having to go up at rite angles if u get me
