Simple one yes I know but you would not believe how long it took me to work out where this item was
I'm talking about the plastic item that lives under the centre console, not the metallic fuel ECU that lives on the right hand side of the drivers footwell (remember I referring to a RH drive car)...
So, easy enough, just remove the section of carpet on the left hand side of the drivers footwell.
Then gently pull out the ECU with polystyrene holder. Before you pull too far remove the vacuum hose and the multi-plug that is held in place by a screw...
By the way , be careful with the heater outlet surround when removing the carpet you can snap the clips easily on this unless you reach inside through the centre console and push out the securing clips from behind. I am talking about the square piece of plastic visible in the top right of the photo above.
Below is the centre console with the cubby hold things removed, looking down on the location of the ECU. You can see the disconnected vacuum line.
Refitting is easy enough just make sure the multi-plug and vacuum line are secure, the ECU is sat securely in the polystyrene and also when you slide the unit back into the centre console try not to catch any cabling - lift it out of the way.
Hope that helps someone!
How to...replace an ignition ECU
- jamesy12345
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
- chriskay
Re: How to...replace an ignition ECU
And as a precaution, disconnect the battery first. It's been reported that if certain contacts are made before others, some components can get fried.
2 Kings; Chapter 9 Verse 20
- jamesy12345
Thanks Chris, good point.......I didn't do this mind u my battery is usually flat anyway
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
- chriskay
Most of the time you get away with it.
