Hello -
Please could someone tell me the difference between the 1.7 driveshaft and the 2.0/Turbo driveshaft?
I am taking about the left side, with the spider joint that goes directly into the gearbox.
The parts manual lists two part numbers
9031180 -- exc b20f/turbo
9031181 -- b20f/turbo
The parts manual lists also a separate CV joint for the above derivatives
Is it only the CV joint? Is there a difference in length?
Stephen
Difference between driveshafts
1995 480 S 2.0 237,000 Miles
Re: Difference between driveshafts
Hi Suddy,
my only experience with this is comparing a non ABS shaft from a 1.7 non turbo to an ABS shaft from a 1.7 turbo, the ABS/ turbo shaft was around 5mm longer from memory
Fraser
Fraser
'90 940 GL 2.0l Estate
'08 XC90 D5 SE Premium
