I’m a bit of a newbie here (understatement) but, would anybody happen to have a left hand side window regulator laying around? Just managed to fix RH window, the switch was a little toasted but after removing some residue from the switch in the centre console it’s working fine now. Left hand said however is the regulator. Had an auto-electrician to confirm this so now I need the LH side regulator part. If anyone can provide the part (or help source one) that would be splendid!
Many thanks in advance,
Adam
LH Side window regulator needed!
Re: LH Side window regulator needed!
Hello Adam and welcome on board. I can't help with a regulator but this is the best place to find one. Good luck !
