Bypass hatch microswitch
blanki1981
Post by blanki1981 » Mon Mar 11, 2013 6:56 pm
I've got a minor issue with my GT in that sometimes when it is locked up the rear hatch micro switch will trigger and set off the car alarm/horn even though the hatch itself is closed.
I was considering seeing if I could modify/remove the micro switch so that the car thinks the hatch is always closed and was wondering if anyone has done anything similar?
Current: C30 1.8 SE (2007)
Previous: V40, 5x 480's, 440 & a VW Polo
Re: Bypass hatch microswitch
Post by Alan 480 » Mon Mar 11, 2013 7:48 pm
can't see why it CANT be bypassed and left in 'closed' mode or look for a new one ex RS / Farnell / Maplin?
Post by glasgowjim » Mon Mar 11, 2013 8:45 pm
Of course you can by pass the switch but it is far better to source a replacement part.
Think about it :eek:
