oldgitdave
Post
by oldgitdave » Fri Jul 10, 2015 6:34 pm
Hi folks,
Drove Dusty home from work today & parked her up on the grass verge. Went out to move her into the garage (yes I have space for a car
), turned the key; nothing
![Crying :cry:](./images/smilies/cry.gif)
. All dash lights ok but no cranking. Thought maybe starter motor (had this before with my Celebration) so tried again. Next thing lots of smoke & burning from behind the steering wheel
![Confused :?](./images/smilies/icon_confused.gif)
. Sh*t, I thought she was going to catch fire
![Surprised :eek:](./images/smilies/eek.gif)
. Switched off quick & the smoke died down. Got the wife to help push her into the garage & have disconnected the battery. Guess there's a short on the
ignition switch somewhere but electrical stuff is well outside my area. Shes a 1995 ES so has an airbag (may need to remove the steering wheel?) Are the
ignition switches readily available & if so what sort of job is it? Any advise greatly appreciated.
Regards,
Dave
1995 'M' 480 ES Auto S/R 'Dusty'
2010 RAV4
2002 S60 2.0L Turbo Auto
1995 'N' 480 Celebration Auto 443/480
Post
by glasgowjim » Fri Jul 10, 2015 7:36 pm
Check the
switch first as you dont have to touch the airbag to remove cowling (I have done so numerous times on late model 480's)
A if it is the
ignition switch thats faulty then just remove the cowling it can be done without removing the steering wheel then remove the little circular
switch on left hand side (remember the grubb screw) put car in neutral and just turn the
switch your car should start if its the key lock at fault but I doubt it. if the
switch is at fault it should show signs of burning just disconnect and hot wire the car.
Although this is for a non air bag car it gives you an idea of what is needed.
http://www.volvo-480-europe.org/forum/v ... 24&t=18370
B To remove the airbag firstly
disconnect the battery for 30 mins before doing any thing about the airbag. This ensures that you are perfectly safe from any accidental activation
That done you can remove the air bag by turning the steering wheel to one side and inserting an allen key into the hole at the back of the steering wheel and loosening the screw it wont fall out by the way. repeat for the other side now remove air bag carefully and slowly as it is connected to the car electrically by a short wire connector.Now disconnect the wire and totallt remove the airbag.
oldgitdave
Post
by oldgitdave » Fri Jul 10, 2015 7:51 pm
Thanks guru Jim
It'll be Sunday at the earliest before I can look at this. Hopefully it will be obvious once the cowling is off. I'll report back as soon as I can. Obviously I want a permanent fix rather than hot wiring but at least that'll confirm where the problem lies.
Cheers,
Dave
2010 RAV4
Post
by glasgowjim » Sat Jul 11, 2015 9:38 am
Also if I remeber correctly the wiring wrapped in YELLOW insulating tape is the airbag wiring.
oldgitdave
Post
by oldgitdave » Sat Jul 11, 2015 11:33 am
Got up early this morning to investigate. Finally managed to get the cowling off without removing the steering wheel. Found that the white & blue wire is badly burnt. Hope this photo works, it's the first time I've tried it
Anyway I disconnected & removed the actual
switch & I've looked inside it and it all looks OK. There doesn't seem to be an obvious short circuit anywhere. So I reconnected the wiring & the battery & tried to start her using a screwdriver. No cranking at all & got smoke from the same wire. I don't suppose I should have expected anything else really. I don't know how to try hot wiring, whether it would help or not I don't know? So at the moment I'm stumped
![Sad :(](./images/smilies/icon_sad.gif)
Any ideas where to go from here?
Dave
2010 RAV4
doingitsideways
Post
by doingitsideways » Sat Jul 11, 2015 5:30 pm
Chances are, the red is permanent live and the burnt wire is the feed to the starter solenoid.
To test, just snip the wires (leaving enough to reconnect afterward) and connect the two together before the switch. The starter should then run.
If it was me, I'd be suspecting the starter solenoid at fault.
Hammers can't fix a 480!!!
Post
by glasgowjim » Sat Jul 11, 2015 9:56 pm
Steve thats sounds right the starter motor/solenoid can sink a lot of juice.
I should have some spare loom lying around must see if I can find it.
oldgitdave
Post
by oldgitdave » Sun Jul 12, 2015 8:06 am
Thanks Steve, Jim,
I was thinking maybe it's a solenoid problem as you say.
Replacing the loom
![Shocked :shock:](./images/smilies/shocked.gif)
wow that sounds like a horrendous job! Will the wire be burnt along its entire length then, or just the bit up near the
switch? I only saw smoke from near the
switch. I was hoping just to reinsulate after removing a bit more of the blue tape.
I'm away from home at the moment but I might have a spare starter that I could get refurbished. The solenoid is part of the starter if I remember correctly? The next problem is getting the car high enough to get underneath to do the change over - can't start it so can't get it on the ramps
I'll let you know how I get on.
Cheers,
Dave
2010 RAV4
eye of ra
Post
by eye of ra » Sun Jul 12, 2015 9:30 am
Try selecting anything other than Park or Neutral and then try and start the car if you no longer get smoke that will eliminate most of the starter circuit and point almost certainly to the starter/solenoid. If it still smokes your problem is elsewhere.
The wire will be melted to some degree inside all the way along. The smoke only came from where it melted to the surface.
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
Post
by glasgowjim » Sun Jul 12, 2015 1:43 pm
oldgitdave are you near glasgow?
oldgitdave
Post
by oldgitdave » Sun Jul 12, 2015 3:40 pm
glasgowjim wrote:oldgitdave are you near glasgow?
Miles away Jim, I'm near Derby.
Tried what "eye of ra" suggested & it doesn't burn when not in neutral or park, so looking even more like solenoid. Thanks for that.
I've peeled the blue insulating tape back as far as I can & there's what looks to be a splice from one wire to two of the same colour (white with blue stripe). Very difficult to see but the two wires don't seem burnt. I guess they've shared the overload? I reckon I could do a repair from the splice.
Couldn't find an old starter motor so must have got rid when I sold my Celebration. Will probably buy a new one on fleabay but there are so many that seem to be compatible but have different ratings 0.85kw to 1.4kw. Obviously the smaller rated ones are cheaper & I suppose will put less load on the damaged wiring. Any idea which one I need or doesn't it matter?
Dave
2010 RAV4
doingitsideways
Post
by doingitsideways » Sun Jul 12, 2015 6:21 pm
As for swapping it out, I'm pretty sure I've done one from above before now on a non turbo car.
oldgitdave
Post
by oldgitdave » Sun Jul 12, 2015 6:31 pm
Well I'll have another look. I'm not as bendy as I used to be
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
. Does the exhaust manifold need to removed?
2010 RAV4
doingitsideways
Post
by doingitsideways » Sun Jul 12, 2015 8:25 pm
I don't think so.
Was a while ago, mind.
I'd definitely remember if I had to remove the manifold though, right pig of a job, that!
eye of ra
Post
by eye of ra » Mon Jul 13, 2015 6:37 pm
Where it splits one wire will be undamaged as it goes to the ECU and is not shorting out (as proved by no smoke when not in P or N) the other one goes to the solenoid of the starter (via the switch on autos) and will be damaged to some extent all the way along it.
The size of the starter motor won’t realy matter as the burnt wire only goes to the solenoid to trigger the starter motor the main current goes through a different wire that is much thicker.
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
oldgitdave
Post
by oldgitdave » Thu Jul 23, 2015 7:07 pm
OK, I've finally managed to get the old starter off from the top. Pretty sure its the original. The worst bit was getting the heat shield off, what a pig of a job
. Anyhoo, the small wire going to the solenoid isn't the same colour as the burnt one from the
ignition switch, it's a slightly heavier gauge and shows no sign of burning. I wonder if the heavier gauge wire comes from the auto transmission inhibitor
switch & isn't burnt simply because it's thicker? Otherwise the problem might be elsewhere
![Angry :angry:](./images/smilies/angry.gif)
Unfortunately the new starter has a spade connector for the small wire & the old one had a post connection so I'll have to change that tomorrow before trying to get everything back together. Must say I'm not that confident the solenoid is the problem given what I've just described. Guess I'll soon find out!
2010 RAV4
oldgitdave
Post
by oldgitdave » Fri Jul 24, 2015 12:35 pm
Well everything is back together and guess what?.......It's exactly the bloody same
![Angry or In a Bad Mood :badmood:](./images/smilies/angry2.gif)
. Obviously the white/blue wire is earthing out somewhere else. The auto box inhibitor
switch is working correctly, I've proved that. Other than trying to get it to an auto electrician (££££££ ouch!) I'm stumped. It might be a while before I can get this sorted
![Crying Hard :cryhard:](./images/smilies/crying.gif)
2010 RAV4
Post
by glasgowjim » Fri Jul 24, 2015 4:29 pm
Okay I havent worked on an auto so but....
From what you said the problem starts when you hold the key at 3 position to engage starter.
When I had an ignition fault with one of my daughters 480's I solved it by hotwiring the ignition just put the ignition on (pos 2) and connected the solenoid to the battery and the car started. Having done that I just put a push to make switch under the dash to start car.
Do a search for " stone age technology " on here for more details
eye of ra
Post
by eye of ra » Fri Jul 24, 2015 6:24 pm
Looking at the latest diagram I have (dated 1991, so might not cover 1995) my money would be on the CEM. Disconnect it, put the car in P or N if you don’t get smoke you need a new CEM if it still smokes it’s in the wiring between the auto switch and the CEM.
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
oldgitdave
Post
by oldgitdave » Fri Jul 24, 2015 6:42 pm
I'd had some thoughts the CEM might be the issue following on from today's dismal failure, but as I'd just parked her up when the starting problem happened with no running issues whatsoever I'd thought it couldn't be that. I do have a CEM3 spare so will look at the wiring to that to see if there's a smoking gun, looking particularly for a white wire with a blue trace. It's left of the passenger side footwell, right? (UK car).
Failing anything found I will try Jims starting advice in the morning and see what happens.
Thanks for your all your help guys
Cheers,
Dave
2010 RAV4
