Green or red dipstick in engine on later models
- coyote1980
- Volvo 480 Club Europe CREW
Hi,
I heard something about there being a difference between engines with a red or green dipstick in them. I believe the later 480 left the factory with a red dipstick, but they found out that 'something' was wrong at the dealers later, fixed it, and fitted a green dipstick to make sure other dealers could see this 'construction error' was solved.
I have a green dipstick in my 2-liter and a red one in my Turbo Collection and hope someone here can give me some info on this
Thanx!
Thanx!
- Agwa Moose
- coyote1980
- coyote1980
Yeah, the older 2-liters have a bad reputation when it comes to oil-leaks! So it wasn't something related to callbacks, but just the introduction of a new type 2-liter engine.rpruen wrote:From what I can tell it was a different engine type, mostly to reduce oil usage. The engine doesn't have cooling oil sprays to the underside of the pistons.
Richard
other
other things that were changed on the later 2.0's were an other motormanagement and camshaft.(and the dipstick colour).
greetz
greetz
Some 2 litre cars are the subject of a call-back action: they drill a 1mm hole under the 2nd (?) piston ring, to cure excess oil consumption. This is missing on certain models, somehow it did not happen at the factory.
I hope the info is correct, I recalled it from a discussion 3,5 years ago when I bought my 480.
480 Turbo, '93, White
Changes on B20F 208/209 (116/118 old B20F)
New
Pistons and rings
Camshaft
Crankshaft and Main bearings
Connecting rods
No piston cooling
Inlet manifold
Throttle control(house or body dont know the english word) with adjusting screw for base settings.
Oilcapacity 5.7L with filter, 2.2L between max and min
Green dipstick.
New
Pistons and rings
Camshaft
Connecting rods
No piston cooling
Inlet manifold
Green dipstick.
- coyote1980
That´s about what I´ve read on a Finnish volvo page..no talk of 480´s though, just late 2l 440/460. Must be because 480´s wasn´t imported to Finland after 1989/90, if I remember right.Some 2 litre cars are the subject of a call-back action: they drill a 1mm hole under the 2nd (?) piston ring, to cure excess oil consumption. This is missing on certain models, somehow it did not happen at the factory.
btw.I looked under the bonnet of my 2.0l -> green dipstick.
Nice info Swe480T!
